Salta al contenuto principale
Acer Aspire V5-572 Bottom Cover Replacement
Cosa ti serve
Panoramica Video
  1. Acer Aspire V5-572 Bottom Cover Replacement, Bottom Cover: passo 1, immagine 1 di 1
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. Acer Aspire V5-572 Bottom Cover Replacement: passo 2, immagine 1 di 1
    • If there is a plastic storage tray in the laptop, remove it.
  3. Acer Aspire V5-572 Bottom Cover Replacement: passo 3, immagine 1 di 3 Acer Aspire V5-572 Bottom Cover Replacement: passo 3, immagine 2 di 3 Acer Aspire V5-572 Bottom Cover Replacement: passo 3, immagine 3 di 3
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
  4. Acer Aspire V5-572 Bottom Cover Replacement: passo 4, immagine 1 di 1
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
Conclusione
ZFix
Membro da: 12/09/13
194.135 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
326 Membri
1.670 Guide realizzate
1Commento della guida
Hello, I'm just trying to find this bottom casing -- anywhere -- and cannot seem to be able to find or purchase one. Often the wrong one comes up when I search (as evidenced by vents in the wrong places). Any ideas? Thanks in advance.
bellemcc - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 28
Tutti i Tempi: 4,007
