Salta al contenuto principale
Acer Aspire V5-571-6889 Motherboard Replacement
Cosa ti serve
  1. Acer Aspire V5-571-6889 Motherboard Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Flip laptop over so that the back is facing upward.
    • Push switch to the right.
    • Pull battery away from the laptop.
  2. Acer Aspire V5-571-6889 Motherboard Replacement: passo 2, immagine 1 di 1
    • Use a #0 Phillips head screw driver to remove all of the screws.
  3. Acer Aspire V5-571-6889 Motherboard Replacement: passo 3, immagine 1 di 1
    • Flip laptop back over.
    • Open the laptop.
    • Wedge a prying tool between the keyboard and laptop body seam to remove keyboard.
    • Be careful not to bend the keyboard too much or break the tabs that connect the keyboard to the laptop.
  4. Acer Aspire V5-571-6889 Motherboard Replacement: passo 4, immagine 1 di 1
    • Gently lift keyboard.
    • Disconnect keyboard from the laptop.
  5. Acer Aspire V5-571-6889 Motherboard Replacement, Remove Upper Cover: passo 5, immagine 1 di 1
    • Disconnect the two ribbon cables at the near left.
    • Remove six screws: ⁃ one by the left most ribbon cable connector ⁃ one mid-right center ⁃ one on the near edge left of center ⁃ three across the back
    • Use a prying tool to remove the upper cover.
  6. Acer Aspire V5-571-6889 Motherboard Replacement: passo 6, immagine 1 di 1
    • Locate the hard drive.
    • Lift the hard drive.
    • Disconnect hard drive.
  7. Acer Aspire V5-571-6889 Motherboard Replacement, Motherboard: passo 7, immagine 1 di 1
    • Use #0 Phillips screw driver to remove the 2.5 x 5 mm with screw attached to the Motherboard.
  8. Acer Aspire V5-571-6889 Motherboard Replacement: passo 8, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use Tweezers to remove the antenna cables attached to the Wi-Fi card.
  9. Acer Aspire V5-571-6889 Motherboard Replacement: passo 9, immagine 1 di 1
    • Use #0 Phillips screw driver to remove the two 2.5 x 5 mm Phillips #0 screws connecting the Wi-Fi card to the Motherboard.
  10. Acer Aspire V5-571-6889 Motherboard Replacement: passo 10, immagine 1 di 1
    • Lift and pull out the Wi-Fi card.
  11. Acer Aspire V5-571-6889 Motherboard Replacement: passo 11, immagine 1 di 1
    • Use #0 Phillips screw driver to remove the 2.5 x 5 mm Phillips #0 screw on the CD-ROM Drive.
  12. Acer Aspire V5-571-6889 Motherboard Replacement: passo 12, immagine 1 di 1
    • Lift and pull out the CD-ROM Drive.
  13. Acer Aspire V5-571-6889 Motherboard Replacement: passo 13, immagine 1 di 1
    • Use #0 Phillips screw driver to remove the 2 x 3 mm Phillips #0 screw holding down CD-ROM connector.
  14. Acer Aspire V5-571-6889 Motherboard Replacement: passo 14, immagine 1 di 1
    • Pull out the CD-ROM Drive connector.
  15. Acer Aspire V5-571-6889 Motherboard Replacement: passo 15, immagine 1 di 2 Acer Aspire V5-571-6889 Motherboard Replacement: passo 15, immagine 2 di 2
    • Use Tweezers to remove the tape covering the display cable connector.
    • Gently disconnect the display cable connector.
  16. Acer Aspire V5-571-6889 Motherboard Replacement: passo 16, immagine 1 di 1
    • Gently peel back the black cloth tape holding the wires in place.
  17. Acer Aspire V5-571-6889 Motherboard Replacement: passo 17, immagine 1 di 1
    • Gently lift Motherboard.
    • Do not remove yet. There are some connections that need to be disconnected.
  18. Acer Aspire V5-571-6889 Motherboard Replacement: passo 18, immagine 1 di 1
    • Gently remove the connector underneath the Motherboard.
  19. Acer Aspire V5-571-6889 Motherboard Replacement: passo 19, immagine 1 di 3 Acer Aspire V5-571-6889 Motherboard Replacement: passo 19, immagine 2 di 3 Acer Aspire V5-571-6889 Motherboard Replacement: passo 19, immagine 3 di 3
    • Gently disconnect the three connectors attached to the Motherboard.
  20. Acer Aspire V5-571-6889 Motherboard Replacement: passo 20, immagine 1 di 1
    • Use #0 Philips screw driver to unscrew the three 2.5 mm x 4 mm screws connecting the CPU fan to the Motherboard.
  21. Acer Aspire V5-571-6889 Motherboard Replacement: passo 21, immagine 1 di 1
    • The motherboard is ready to be replaced.
    • Attach the CPU fan to the new motherboard during reassembling.
Conclusione
Samuel Miguel
Membro da: 07/08/19
241 Reputazione
1 Guida realizzata
IUPUI, Team S2-G4, Harley Summer 2019 Membro di IUPUI, Team S2-G4, Harley Summer 2019
IUPUI-HARLEY-SU19S2G4
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 15
Tutti i Tempi: 605
