Salta al contenuto principale
Acer Aspire V5-571 Upper Cover Replacement
Cosa ti serve
  1. Acer Aspire V5-571 Upper  Cover Replacement, Keyboard: passo 1, immagine 1 di 3 Acer Aspire V5-571 Upper  Cover Replacement, Keyboard: passo 1, immagine 2 di 3 Acer Aspire V5-571 Upper  Cover Replacement, Keyboard: passo 1, immagine 3 di 3
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
  2. Acer Aspire V5-571 Upper  Cover Replacement: passo 2, immagine 1 di 3 Acer Aspire V5-571 Upper  Cover Replacement: passo 2, immagine 2 di 3 Acer Aspire V5-571 Upper  Cover Replacement: passo 2, immagine 3 di 3
  3. Acer Aspire V5-571 Upper  Cover Replacement, Optical Drive: passo 3, immagine 1 di 3 Acer Aspire V5-571 Upper  Cover Replacement, Optical Drive: passo 3, immagine 2 di 3 Acer Aspire V5-571 Upper  Cover Replacement, Optical Drive: passo 3, immagine 3 di 3
    • Remove the screw securing the Optical drive and gently press the drive to show slightly as at the second pic.
    • Slide the drive to the left and remove it.
  4. Acer Aspire V5-571 Upper  Cover Replacement, Upper  Cover: passo 4, immagine 1 di 3 Acer Aspire V5-571 Upper  Cover Replacement, Upper  Cover: passo 4, immagine 2 di 3 Acer Aspire V5-571 Upper  Cover Replacement, Upper  Cover: passo 4, immagine 3 di 3
    • Remove 4x phillips screws and disconnect:
    • Power On button flex cable
    • Touch pad flex cable
    • Remove 18x Phillips screws from the bottom cover.
    • Remove any memory SD Card from the Card reader.
    • Start opening with a plastic opening tool.
  5. Acer Aspire V5-571 Upper  Cover Replacement: passo 5, immagine 1 di 3 Acer Aspire V5-571 Upper  Cover Replacement: passo 5, immagine 2 di 3 Acer Aspire V5-571 Upper  Cover Replacement: passo 5, immagine 3 di 3
    • Carefully separate the upper cover and remove it.
Conclusione
ZFix
Membro da: 12/09/13
191.341 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.541 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 18
Tutti i Tempi: 2,999
