Salta al contenuto principale
Acer Aspire V5-571 Loudspeakers Replacement
Cosa ti serve
Panoramica Video
  1. Acer Aspire V5-571 Loudspeakers Replacement, Keyboard: passo 1, immagine 1 di 3 Acer Aspire V5-571 Loudspeakers Replacement, Keyboard: passo 1, immagine 2 di 3 Acer Aspire V5-571 Loudspeakers Replacement, Keyboard: passo 1, immagine 3 di 3
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
  2. Acer Aspire V5-571 Loudspeakers Replacement: passo 2, immagine 1 di 3 Acer Aspire V5-571 Loudspeakers Replacement: passo 2, immagine 2 di 3 Acer Aspire V5-571 Loudspeakers Replacement: passo 2, immagine 3 di 3
  3. Acer Aspire V5-571 Loudspeakers Replacement, Optical Drive: passo 3, immagine 1 di 3 Acer Aspire V5-571 Loudspeakers Replacement, Optical Drive: passo 3, immagine 2 di 3 Acer Aspire V5-571 Loudspeakers Replacement, Optical Drive: passo 3, immagine 3 di 3
    • Remove the screw securing the Optical drive and gently press the drive to show slightly as at the second pic.
    • Slide the drive to the left and remove it.
  4. Acer Aspire V5-571 Loudspeakers Replacement, Upper  Cover: passo 4, immagine 1 di 3 Acer Aspire V5-571 Loudspeakers Replacement, Upper  Cover: passo 4, immagine 2 di 3 Acer Aspire V5-571 Loudspeakers Replacement, Upper  Cover: passo 4, immagine 3 di 3
    • Remove 4x phillips screws and disconnect:
    • Power On button flex cable
    • Touch pad flex cable
    • Remove 18x Phillips screws from the bottom cover.
    • Remove any memory SD Card from the Card reader.
    • Start opening with a plastic opening tool.
  5. Acer Aspire V5-571 Loudspeakers Replacement: passo 5, immagine 1 di 3 Acer Aspire V5-571 Loudspeakers Replacement: passo 5, immagine 2 di 3 Acer Aspire V5-571 Loudspeakers Replacement: passo 5, immagine 3 di 3
    • Carefully separate the upper cover and remove it.
  6. Acer Aspire V5-571 Loudspeakers Replacement, HDD (Hard Disk Drive): passo 6, immagine 1 di 3 Acer Aspire V5-571 Loudspeakers Replacement, HDD (Hard Disk Drive): passo 6, immagine 2 di 3 Acer Aspire V5-571 Loudspeakers Replacement, HDD (Hard Disk Drive): passo 6, immagine 3 di 3
  7. Acer Aspire V5-571 Loudspeakers Replacement, Wi-Fi Half Mini PCIe card: passo 7, immagine 1 di 2 Acer Aspire V5-571 Loudspeakers Replacement, Wi-Fi Half Mini PCIe card: passo 7, immagine 2 di 2
    • Remove one Phillips screw, securing th WLan card and disconnect the two coaxial antenna cables.
    • Remove the Wi-Fi card.
  8. Acer Aspire V5-571 Loudspeakers Replacement, Mother Board: passo 8, immagine 1 di 3 Acer Aspire V5-571 Loudspeakers Replacement, Mother Board: passo 8, immagine 2 di 3 Acer Aspire V5-571 Loudspeakers Replacement, Mother Board: passo 8, immagine 3 di 3
    • Remove the Memory Cover.
    • Disconnect the Loudspeaker cable connector.
  9. Acer Aspire V5-571 Loudspeakers Replacement: passo 9, immagine 1 di 3 Acer Aspire V5-571 Loudspeakers Replacement: passo 9, immagine 2 di 3 Acer Aspire V5-571 Loudspeakers Replacement: passo 9, immagine 3 di 3
    • Remove two Phillips screw from the Mother board and from the Optical drive SATA adapter.
    • Disconnect the LCD Display flex cable.
    • Disconnect the DC Jack cable.
    • Carefully remove the Optical drive SATA adapter.
    • We will disconnect the battery cable when we pick up the board.
  10. Acer Aspire V5-571 Loudspeakers Replacement: passo 10, immagine 1 di 3 Acer Aspire V5-571 Loudspeakers Replacement: passo 10, immagine 2 di 3 Acer Aspire V5-571 Loudspeakers Replacement: passo 10, immagine 3 di 3
    • Carefully pick up the Mother board and disconnect the Battery cable.
  11. Acer Aspire V5-571 Loudspeakers Replacement, Loudspeakers: passo 11, immagine 1 di 2 Acer Aspire V5-571 Loudspeakers Replacement, Loudspeakers: passo 11, immagine 2 di 2
    • There are two Loudspeakers. Each of them is held by two Phillips screws.
    • Did you do it successfully?
Conclusione
ZFix
Membro da: 12/09/13
191.182 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.521 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,628
