Salta al contenuto principale
Acer Aspire V5-552PG-X469 Key Replacement
Cosa ti serve
  1. Acer Aspire V5-552PG-X469 Key Replacement, Keyboard: passo 1, immagine 1 di 1
    • Place the end of a plastic opening tool underneath the edge of the broken key.
    • Gently pry up on the key until it comes loose.
    • Pry carefully to make sure you do not damage any of the internal hardware while removing the keys.
  2. Acer Aspire V5-552PG-X469 Key Replacement: passo 2, immagine 1 di 1
    • Pick up the key to remove it.
    • If any debris is found underneath the key, clean it out with an air canister or cotton swab.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 12
Tutti i Tempi: 941
