Salta al contenuto principale
Acer Aspire V5-131-2680 Motherboard Replacement
Cosa ti serve
  1. Acer Aspire V5-131-2680 Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • Turn the Acer Aspire upside down, with the stickers facing up.
    • Unplug the charger and make sure the device is off.
  2. Acer Aspire V5-131-2680 Motherboard Replacement: passo 2, immagine 1 di 1
    • Unscrew the twenty M2 x 6 screws using a Phillips #00 screwdriver.
    • Unplug the battery and disconnect all the components connected to the motherboard.
    • Pry open the bottom of the laptop using the opening tool.
  3. Acer Aspire V5-131-2680 Motherboard Replacement: passo 3, immagine 1 di 3 Acer Aspire V5-131-2680 Motherboard Replacement: passo 3, immagine 2 di 3 Acer Aspire V5-131-2680 Motherboard Replacement: passo 3, immagine 3 di 3
    • Disconnect the two components that are attached to the motherboard and keyboard.
    • The large ribbon cable is disconnected by pulling apart the two white tabs found on each side of the connection and lifting the cable out.
    • The small wire can be removed by simply pulling on the blue tape
  4. Acer Aspire V5-131-2680 Motherboard Replacement: passo 4, immagine 1 di 1
    • Unscrew the three M2 x 3 Phillips screws on the motherboard.
  5. Acer Aspire V5-131-2680 Motherboard Replacement: passo 5, immagine 1 di 3 Acer Aspire V5-131-2680 Motherboard Replacement: passo 5, immagine 2 di 3 Acer Aspire V5-131-2680 Motherboard Replacement: passo 5, immagine 3 di 3
    • Disconnect all the big and small wires connected to the motherboard.
    • The big wires must be squeezed on each side of the connection to release the tabs, then pull the cable out.
    • The small wires can be removed simply by pulling the cable out of the connection
  6. Acer Aspire V5-131-2680 Motherboard Replacement: passo 6, immagine 1 di 1
    • Gently pull the motherboard up and to the right at the same time.
  7. Acer Aspire V5-131-2680 Motherboard Replacement: passo 7, immagine 1 di 1
    • Once the motherboard is out, take off the tape that is holding the fan and the motherboard together. Push the fan down and it will come off.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 18
Tutti i Tempi: 261
