Salta al contenuto principale
Acer Aspire V5-131-2680 Hard Drive Replacement
  1. Acer Aspire V5-131-2680 Hard Drive Replacement, Bottom Cover: passo 1, immagine 1 di 1
    • Make sure your laptop is powered down and completely closed before proceeding.
    • Turn your laptop upside down. The stickers should be facing up.
  2. Acer Aspire V5-131-2680 Hard Drive Replacement: passo 2, immagine 1 di 2 Acer Aspire V5-131-2680 Hard Drive Replacement: passo 2, immagine 2 di 2
    • To open the bottom compartment, put one finger underneath the laptop and firmly grab the compartment with your thumb.
    • You can also use both thumbs for more pressure.
    • Carefully slide the bottom compartment with your thumb until you feel it pop out of place.
  3. Acer Aspire V5-131-2680 Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 2 Acer Aspire V5-131-2680 Hard Drive Replacement, Hard Drive: passo 3, immagine 2 di 2
    • On the sides of the hard drive, you will see two side tabs. This is what holds the hard drive in place.
    • Place your finger on the left tab and press on it to loosen the hard drive.
    • After the hard drive is loose, slide it out of the compartment.
    • Do not remove your finger from the side tab while removing the hard drive.
  4. Acer Aspire V5-131-2680 Hard Drive Replacement: passo 4, immagine 1 di 1
    • You have successfully removed the hard drive from the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 156
