Salta al contenuto principale
Acer Aspire V5-131-2680 Battery Replacement
Cosa ti serve
  1. Acer Aspire V5-131-2680 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure your laptop is powered down and completely closed before proceeding.
    • Turn your laptop upside down. The stickers should be facing up.
  2. Acer Aspire V5-131-2680 Battery Replacement: passo 2, immagine 1 di 2 Acer Aspire V5-131-2680 Battery Replacement: passo 2, immagine 2 di 2
    • To open the bottom compartment, put one finger underneath the laptop and firmly grab the compartment with your thumb.
    • You can also use both thumbs for more pressure.
    • Carefully slide the bottom compartment with your thumb until you feel it pop out of place.
  3. Acer Aspire V5-131-2680 Battery Replacement: passo 3, immagine 1 di 2 Acer Aspire V5-131-2680 Battery Replacement: passo 3, immagine 2 di 2
    • In front of the battery, you will find a sliding flap. This is a battery-release lock.
    • Place your finger on the latch and slide the latch to open. Pull out the battery from its compartment.
    • Do not remove your finger from the latch while sliding the battery out.
    • Once the battery is out, release the latch.
Conclusione
Naomi Zaldana
Membro da: 09/26/22
147 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 192
