Salta al contenuto principale
Acer Aspire V5-131-2629 Battery Replacement
Cosa ti serve
  1. Acer Aspire V5-131-2629 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Carefully turn your Acer Aspire V5-131-2629 upside down, so that the battery cell is visible and nearest to you.
  2. Acer Aspire V5-131-2629 Battery Replacement: passo 2, immagine 1 di 1
    • Identify the small, oval slide switch on the left hand side of the laptop, directly above the battery.
  3. Acer Aspire V5-131-2629 Battery Replacement: passo 3, immagine 1 di 1
    • Insert an opening tool into the hole on the right side of the oval switch. Use the opening tool to slide the switch to the right.
  4. Acer Aspire V5-131-2629 Battery Replacement: passo 4, immagine 1 di 2 Acer Aspire V5-131-2629 Battery Replacement: passo 4, immagine 2 di 2
    • With the switch engaged to the right, firmly pull the battery out and towards yourself, parallel to your work surface.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 50
Tutti i Tempi: 4,945
