Introduzione
Your fan is causing an annoying sound? Your fan is not cooling your laptop like it is suppose to be? You want to change your fan but you do not know how? This guide will walk you through step by step on how to do so.
Cosa ti serve
Start the process of removing the bottom cover of the laptop by unscrewing the 8mm screws in the top right and left corners.
Remove the remaining 9 visible screws, which are 5mm in length.
