Salta al contenuto principale
Acer Aspire V5-122P-0889 CPU fan Replacement
Cosa ti serve
  1. Acer Aspire V5-122P-0889 CPU fan Replacement, Battery: passo 1, immagine 1 di 2 Acer Aspire V5-122P-0889 CPU fan Replacement, Battery: passo 1, immagine 2 di 2
    • Start the process of removing the bottom cover of the laptop by unscrewing the 8mm screws in the top right and left corners.
    • Remove the remaining 9 visible screws, which are 5mm in length.
    • Every screw in this laptop can be removed with a Phillips #0 screwdriver.
  2. Acer Aspire V5-122P-0889 CPU fan Replacement: passo 2, immagine 1 di 2 Acer Aspire V5-122P-0889 CPU fan Replacement: passo 2, immagine 2 di 2
    • Towards the top right corner of the laptop, there is a rubber piece covering the final screw holding the cover on, as well as a set of pins. Use your fingernail to remove this piece of rubber, and then unscrew the hidden 5mm screw.
  3. Acer Aspire V5-122P-0889 CPU fan Replacement: passo 3, immagine 1 di 2 Acer Aspire V5-122P-0889 CPU fan Replacement: passo 3, immagine 2 di 2
    • Going around the edges of the laptop, apply light to moderate amounts of pressure away from the laptop to unseat the cover so that it can be removed. Once you have removed the cover, place it face-up in a safe place to avoid getting the inside of the cover dirty.
    • If you are having trouble unseating the cover by hand, a nylon spudger can be run around the perimeter of the laptop to help lift the cover away from the case.
  4. Acer Aspire V5-122P-0889 CPU fan Replacement: passo 4, immagine 1 di 2 Acer Aspire V5-122P-0889 CPU fan Replacement: passo 4, immagine 2 di 2
    • Carefully unscrew the two 5mm screws holding the battery in place.
  5. Acer Aspire V5-122P-0889 CPU fan Replacement: passo 5, immagine 1 di 1
    • Carefully use light upward pressure to unseat the battery from the case, but do not pull on the cord or try and completely remove the battery from the case.
  6. Acer Aspire V5-122P-0889 CPU fan Replacement: passo 6, immagine 1 di 2 Acer Aspire V5-122P-0889 CPU fan Replacement: passo 6, immagine 2 di 2
    • Finally, disconnect the battery from the motherboard by undoing the power connector. To undo the connector, simply apply light to moderate pull on the sides of the connector.
  7. Acer Aspire V5-122P-0889 CPU fan Replacement, CPU fan: passo 7, immagine 1 di 2 Acer Aspire V5-122P-0889 CPU fan Replacement, CPU fan: passo 7, immagine 2 di 2
    • Remove the three screws that hold the fan into place.
    • Two of the screws remain attached to the metal heat-sink part of the fan after being unscrewed. This is normal, as they are build into the heat-sink.
  8. Acer Aspire V5-122P-0889 CPU fan Replacement: passo 8, immagine 1 di 1
    • Disconnect the power cable that connects the fan to the motherboard.
  9. Acer Aspire V5-122P-0889 CPU fan Replacement: passo 9, immagine 1 di 1
    • Remove the CPU fan from the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,376
