Introduzione
If your battery will not charge fully, drains quickly, or shows inconsistent battery percentage this would be a good replacement. Prior to starting this guide, disconnect the power supply from the laptop.
Cosa ti serve
Remove the nine 4mm screws with a PH0 screwdriver.
Remove the two 6mm screws with a PH0 screwdriver.
Altre 4 persone hanno completato questa guida.
