Salta al contenuto principale
Acer Aspire V3-771G Hard Drive Replacement
Cosa ti serve
  1. Acer Aspire V3-771G Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 2 Acer Aspire V3-771G Hard Drive Replacement, Hard Drive: passo 1, immagine 2 di 2
    • Shut down the laptop.
    • Remove the power charging cord from the laptop.
  2. Acer Aspire V3-771G Hard Drive Replacement: passo 2, immagine 1 di 3 Acer Aspire V3-771G Hard Drive Replacement: passo 2, immagine 2 di 3 Acer Aspire V3-771G Hard Drive Replacement: passo 2, immagine 3 di 3
    • Flip the laptop over, and find the battery compartment.
    • Use your fingers to move the orange slider located just below the battery compartment to the right.
    • Do not touch the battery connectors on the battery or laptop.
    • Lift the battery up and remove from the compartment.
  3. Acer Aspire V3-771G Hard Drive Replacement: passo 3, immagine 1 di 2 Acer Aspire V3-771G Hard Drive Replacement: passo 3, immagine 2 di 2
    • Using the screwdriver, remove the nine 8 mm screws from the panel on the back of the laptop.
    • Gently lift the panel up from the open slot, use the opening tools as necessary, to free the panel from the laptop.
  4. Acer Aspire V3-771G Hard Drive Replacement: passo 4, immagine 1 di 2 Acer Aspire V3-771G Hard Drive Replacement: passo 4, immagine 2 di 2
    • Remove the two screws holding the hard drive sled in place.
    • While grounding yourself, gently pull the black tag straight back, not up, to free the hard drive.
  5. Acer Aspire V3-771G Hard Drive Replacement: passo 5, immagine 1 di 3 Acer Aspire V3-771G Hard Drive Replacement: passo 5, immagine 2 di 3 Acer Aspire V3-771G Hard Drive Replacement: passo 5, immagine 3 di 3
    • Using the screwdriver, remove the four 4 mm screws from the hard drive sled.
    • Carefully remove the hard drive. A new one may now be installed.
Conclusione
Altre 9 persone hanno completato questa guida.
David Walker
Membro da: 10/11/14
341 Reputazione
1 Guida realizzata
USF Tampa, Team 1-36, Donnelly Fall 2014 Membro di USF Tampa, Team 1-36, Donnelly Fall 2014
USFT-DONNELLY-F14S1G36
1 Membro
1 Guida realizzata
Un commento
Please pardon my inquiry. Is the same replacement can be done to Acer Aspire V3-572P-540V? Any reply will be appreciated.
b6789b - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 35
Tutti i Tempi: 13,659
