Salta al contenuto principale
Acer Aspire V3-551-8887 Back Panel Replacement
Cosa ti serve
  1. Acer Aspire V3-551-8887 Back Panel Replacement, Back Panel: passo 1, immagine 1 di 1
    • Locate and remove the two 5.3 mm Phillips #1 screws holding the back panel in place.
  2. Acer Aspire V3-551-8887 Back Panel Replacement: passo 2, immagine 1 di 2 Acer Aspire V3-551-8887 Back Panel Replacement: passo 2, immagine 2 di 2
    • Use a spudger to pry the panel up from the laptop case and remove it.
    • The laptop should now be open with the RAM and wifi chip now accessible.
Conclusione
Cal Poly, Team 8-8, Regan Spring 2014 Membro di Cal Poly, Team 8-8, Regan Spring 2014
CPSU-REGAN-S14S8G8
4 Membri
7 Guide realizzate
Un commento
Is the hard drive accessible for replacement from the bottom? I see black stuff over the drive with the WIFI cables going underneath. Is that removable so one can access the drive from the bottom, or is it accessible from under the keyboard?
danwat1234 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,757
