Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
Removing the back panel gives access to most everything else in the laptop.
  1. Locate and remove the two 5.3 mm Phillips #1 screws holding the back panel in place.
    • Locate and remove the two 5.3 mm Phillips #1 screws holding the back panel in place.
  2. Use a spudger to pry the panel up from the laptop case and remove it. The laptop should now be open with the RAM and wifi chip now accessible.
    • Use a spudger to pry the panel up from the laptop case and remove it.
    • The laptop should now be open with the RAM and wifi chip now accessible.
Conclusione
Jacob Lesinski
Membro da: 22/04/2014
143 Reputazione
1 Guida realizzata
Cal Poly, Team 8-8, Regan Spring 2014 Membro di Cal Poly, Team 8-8, Regan Spring 2014
CPSU-REGAN-S14S8G8
4 Membri
7 Guide realizzate
Is the hard drive accessible for replacement from the bottom? I see black stuff over the drive with the WIFI cables going underneath. Is that removable so one can access the drive from the bottom, or is it accessible from under the keyboard?
danwat1234 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,574
