Salta al contenuto principale
Acer Aspire TimelineX 4830T-6682 Power Plug Replacement Replacement
Cosa ti serve
  1. Acer Aspire TimelineX 4830T-6682 Power Plug  Replacement Replacement, Lower Back Panel: passo 1, immagine 1 di 3 Acer Aspire TimelineX 4830T-6682 Power Plug  Replacement Replacement, Lower Back Panel: passo 1, immagine 2 di 3 Acer Aspire TimelineX 4830T-6682 Power Plug  Replacement Replacement, Lower Back Panel: passo 1, immagine 3 di 3
    • Remove the single screw with a Phillips #0 screwdriver.
    • Use a plastic opening tool on the upper part of the panel to remove it and access the RAM.
    • The other way to remove the panel is by sliding it away from the laptop. The difficulty of sliding it depends on the condition of your laptop.
  2. Acer Aspire TimelineX 4830T-6682 Power Plug  Replacement Replacement, Keyboard: passo 2, immagine 1 di 1
    • Remove the eleven screws that hold that back panel to the laptop using a J0 Phillips screwdriver bit.
  3. Acer Aspire TimelineX 4830T-6682 Power Plug  Replacement Replacement: passo 3, immagine 1 di 3 Acer Aspire TimelineX 4830T-6682 Power Plug  Replacement Replacement: passo 3, immagine 2 di 3 Acer Aspire TimelineX 4830T-6682 Power Plug  Replacement Replacement: passo 3, immagine 3 di 3
    • Place the laptop in the upright position, the lower front touchpad panel should be easily detatched at this point.
    • Remove the lower front touchpad panel by using an angled tweezers to disconnect the only wired tape connected to the motherboard.
  4. Acer Aspire TimelineX 4830T-6682 Power Plug  Replacement Replacement: passo 4, immagine 1 di 1
    • Next, disconnect the 4 wired tapes of the keyboard from the motherboard just like we did with the lower front touchpad panel.
  5. Acer Aspire TimelineX 4830T-6682 Power Plug  Replacement Replacement: passo 5, immagine 1 di 2 Acer Aspire TimelineX 4830T-6682 Power Plug  Replacement Replacement: passo 5, immagine 2 di 2
    • Finally, using an opening tool, gently pry along the edge of the keyboard to separate it from the laptop.
  6. Acer Aspire TimelineX 4830T-6682 Power Plug  Replacement Replacement, Power Plug: passo 6, immagine 1 di 1
    • The power connector is easy to spot once you have removed the keyboard.
  7. Acer Aspire TimelineX 4830T-6682 Power Plug  Replacement Replacement: passo 7, immagine 1 di 1
    • Slide the DVD drive out of the computer to gain access to the cables
  8. Acer Aspire TimelineX 4830T-6682 Power Plug  Replacement Replacement: passo 8, immagine 1 di 2 Acer Aspire TimelineX 4830T-6682 Power Plug  Replacement Replacement: passo 8, immagine 2 di 2
    • The rubber block is attached with a mild adhesive. Use the spudger tool to loosen it
    • Once the block is loose, use the spudger to unhook the wires from their guides.
  9. Acer Aspire TimelineX 4830T-6682 Power Plug  Replacement Replacement: passo 9, immagine 1 di 2 Acer Aspire TimelineX 4830T-6682 Power Plug  Replacement Replacement: passo 9, immagine 2 di 2
    • The body of the plug is glued to the computer. Use the spudger tool to wiggle the plug until it comes loose.
  10. Acer Aspire TimelineX 4830T-6682 Power Plug  Replacement Replacement: passo 10, immagine 1 di 3 Acer Aspire TimelineX 4830T-6682 Power Plug  Replacement Replacement: passo 10, immagine 2 di 3 Acer Aspire TimelineX 4830T-6682 Power Plug  Replacement Replacement: passo 10, immagine 3 di 3
    • Use gentle pressure to pull the plug from its socket on the motherboard. Once the plug is loose, you can pull the entire plug assembly from the computer.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 7
Tutti i Tempi: 387
