Salta al contenuto principale
Acer Aspire TimelineX 4830T-6682 Back Panel Replacement
Cosa ti serve
  1. Acer Aspire TimelineX 4830T-6682 Back Panel Replacement, Lower Back Panel: passo 1, immagine 1 di 3 Acer Aspire TimelineX 4830T-6682 Back Panel Replacement, Lower Back Panel: passo 1, immagine 2 di 3 Acer Aspire TimelineX 4830T-6682 Back Panel Replacement, Lower Back Panel: passo 1, immagine 3 di 3
    • Remove the single screw with a Phillips #0 screwdriver.
    • Use a plastic opening tool on the upper part of the panel to remove it and access the RAM.
    • The other way to remove the panel is by sliding it away from the laptop. The difficulty of sliding it depends on the condition of your laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 7
Tutti i Tempi: 466
