Salta al contenuto principale
Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement
Cosa ti serve
  1. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Power down the laptop.
    • Turn the laptop over so the bottom is facing up and the battery is facing towards you.
  2. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: passo 2, immagine 1 di 1
    • The tab on the right is a locking tab. Slide this tab to the right to unlock it (the red should now be showing).
    • Slide the left tab to the left and hold it there.
  3. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: passo 3, immagine 1 di 2 Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: passo 3, immagine 2 di 2
    • While holding the left tab to the left the battery should easily pull out of the laptop.
  4. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement, Hard Drive: passo 4, immagine 1 di 2 Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement, Hard Drive: passo 4, immagine 2 di 2
    • Place laptop bottom side up, and use a Phillips #1 screwdriver to unscrew the five 8 mm screws from the back panel.
  5. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: passo 5, immagine 1 di 1
    • After removing the back panel, use a Phillips #1 screwdriver to unscrew the two 8 mm screws that hold the retaining piece to the frame.
  6. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: passo 6, immagine 1 di 2 Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: passo 6, immagine 2 di 2
    • Pull the plastic tab toward the frame to disconnect the hard drive SATA.
  7. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: passo 7, immagine 1 di 1
    • Remove the hard drive from the laptop, and use a Phillips #1 screwdriver to unscrew the two 3 mm screws that secure the retaining piece to the hard drive.
Conclusione
Ian Smiley
Membro da: 03/26/19
109 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 579
