Salta al contenuto principale
Acer Aspire TimelineX 1830T-68U118 Fan Replacement
Cosa ti serve
  1. Acer Aspire TimelineX 1830T-68U118 Fan Replacement, Battery: passo 1, immagine 1 di 1
    • Turn your laptop over, and find the laptop battery release button locks for your Acer laptop.
  2. Acer Aspire TimelineX 1830T-68U118 Fan Replacement: passo 2, immagine 1 di 3 Acer Aspire TimelineX 1830T-68U118 Fan Replacement: passo 2, immagine 2 di 3 Acer Aspire TimelineX 1830T-68U118 Fan Replacement: passo 2, immagine 3 di 3
    • Hold the battery release button, and pull the battery out of the laptop.
  3. Acer Aspire TimelineX 1830T-68U118 Fan Replacement, Fan: passo 3, immagine 1 di 3 Acer Aspire TimelineX 1830T-68U118 Fan Replacement, Fan: passo 3, immagine 2 di 3 Acer Aspire TimelineX 1830T-68U118 Fan Replacement, Fan: passo 3, immagine 3 di 3
    • Remove battery before beginning.
    • Use a Phillips #0 screwdriver to remove the 5 screws from the bottom cover.
    • Pry open the cover using the Spudger tool.
  4. Acer Aspire TimelineX 1830T-68U118 Fan Replacement: passo 4, immagine 1 di 3 Acer Aspire TimelineX 1830T-68U118 Fan Replacement: passo 4, immagine 2 di 3 Acer Aspire TimelineX 1830T-68U118 Fan Replacement: passo 4, immagine 3 di 3
    • Remove the keyboard with a plastic opening tool or spudger.
    • There is a plastic film that needs to be gently peeled from the laptop base.
    • Use caution when removing the keyboard as it is fragile.
  5. Acer Aspire TimelineX 1830T-68U118 Fan Replacement: passo 5, immagine 1 di 2 Acer Aspire TimelineX 1830T-68U118 Fan Replacement: passo 5, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove the 4 screws from the motherboard shield.
  6. Acer Aspire TimelineX 1830T-68U118 Fan Replacement: passo 6, immagine 1 di 2 Acer Aspire TimelineX 1830T-68U118 Fan Replacement: passo 6, immagine 2 di 2
    • Remove the motherboard from the base of the laptop by unscrew the screw drivers using PH0 mm Phillips Head.
    • Carefully remove the charger attachment in the top left.
  7. Acer Aspire TimelineX 1830T-68U118 Fan Replacement: passo 7, immagine 1 di 3 Acer Aspire TimelineX 1830T-68U118 Fan Replacement: passo 7, immagine 2 di 3 Acer Aspire TimelineX 1830T-68U118 Fan Replacement: passo 7, immagine 3 di 3
    • Carefully remove the fan from the motherboard by detaching the plastic insert as seen in the pictures
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,231
