Salta al contenuto principale
Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement
Cosa ti serve
  1. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement, Docking Connectors: passo 1, immagine 1 di 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement, Docking Connectors: passo 1, immagine 2 di 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement, Docking Connectors: passo 1, immagine 3 di 3
    • Remove the 8, 5.25 mm screws on the back cover using the screwdriver.
    • Insert the opening tool into the USB port.
    • Carefully remove the back cover using the opening tool.
  2. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 2, immagine 1 di 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 2, immagine 2 di 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 2, immagine 3 di 3
    • Remove the yellow tape from the board cables.
    • Carefully unplug the two board cables from their connectors by pulling on them.
  3. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 3, immagine 1 di 2 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 3, immagine 2 di 2
    • Remove the 2, 4.25 mm screws on the left hand tab that are securing the dock in place.
  4. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 4, immagine 1 di 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 4, immagine 2 di 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 4, immagine 3 di 3
    • Lift up the metal tab on the left side using the opening tool.
    • Using your fingers may be easier than using the opening tool for this particular step, although both can be used.
  5. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 5, immagine 1 di 2 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 5, immagine 2 di 2
    • Remove the 2, 4.25 mm screws on the right hand tab that are securing the dock in place.
  6. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 6, immagine 1 di 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 6, immagine 2 di 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 6, immagine 3 di 3
    • Lift the metal tab on the right side up using the opening tool.
  7. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 7, immagine 1 di 2 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 7, immagine 2 di 2
    • Insert the opening tool between the two sections of the device.
    • Lift up the keyboard section using the opening tool.
  8. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 8, immagine 1 di 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 8, immagine 2 di 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 8, immagine 3 di 3
    • Carefully pull up on the keyboard section using your hands to remove it from the screen section.
  9. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 9, immagine 1 di 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 9, immagine 2 di 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 9, immagine 3 di 3
    • Pull the docking connector off of the screen section.
Conclusione
Altre 2 persone hanno completato questa guida.
Grecia Corrada
Membro da: 03/19/18
1.134 Reputazione
6 Guide realizzate
Baylor, Team S3-G3, Williams Spring 2018 Membro di Baylor, Team S3-G3, Williams Spring 2018
BU-WILLIAMS-S18S3G3
3 Membri
6 Guide realizzate
Un commento
Where do you get the docking ports or whatever it is called? With the magnets
Michael - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 2,922
