Salta al contenuto principale
Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement
Cosa ti serve
  1. Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement, Touchpad: passo 1, immagine 1 di 1
    • Use the Driver with the Phillips PH0 attachment to unscrew the 7 5mm screws from the back panel.
    • This screw does not need to be removed because it doesn't hold the backplate in.
  2. Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: passo 2, immagine 1 di 2 Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: passo 2, immagine 2 di 2
    • Push the plastic opening tool into the crevice between the front and back panel.
    • Pull down on the plastic opening tool like a lever to create space and slide along the crevice to remove the back panel.
  3. Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: passo 3, immagine 1 di 3 Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: passo 3, immagine 2 di 3 Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: passo 3, immagine 3 di 3
    • Gently slide the plastic opening tool under the black clip that is attached to the ribbon cable.
    • Pull down on the plastic opening tool like a lever to flip the black clip and remove the ribbon cable.
    • The black clip doesn't take much force to lift, so be gentle to avoid breaking it.
  4. Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: passo 4, immagine 1 di 1
    • Remove the touchpad.
Conclusione
USF Tampa, Team 3-4, Passmore Fall 2016 Membro di USF Tampa, Team 3-4, Passmore Fall 2016
USFT-PASSMORE-F16S3G4
4 Membri
4 Guide realizzate
Un commento
Thank you for the steps. I want to know if a replacement keyboard is available in the market. I did not find online.
Gibson Castelino - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,568
