Salta al contenuto principale
Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement
Cosa ti serve
  1. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement, Speakers: passo 1, immagine 1 di 3 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement, Speakers: passo 1, immagine 2 di 3 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement, Speakers: passo 1, immagine 3 di 3
    • Wedge your plastic opening tool into the crevice between the volume button and casing to create space.
    • Slide the plastic opening tool along this crevice to pry apart the backing of the tablet.
  2. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: passo 2, immagine 1 di 3 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: passo 2, immagine 2 di 3 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: passo 2, immagine 3 di 3
    • There is one zero insertion force connector that needs to be removed.
    • Use your plastic opening tool to flip up the black clip that secures the ribbon cable to the motherboard.
    • Once the clip is flipped up, the ribbon cable will be safe to remove.
  3. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: passo 3, immagine 1 di 3 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: passo 3, immagine 2 di 3 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: passo 3, immagine 3 di 3
    • To remove the four bundled cable connectors, push against the edges of the connector to loosen it up.
    • Pull the cable away from the connector.
  4. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: passo 4, immagine 1 di 2 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: passo 4, immagine 2 di 2
    • Use a pair of tweezers to gently pull up the speaker closest to the motherboard.
  5. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: passo 5, immagine 1 di 2 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: passo 5, immagine 2 di 2
    • Remove any tape that may be holding down the speakers or wires in place.
  6. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: passo 6, immagine 1 di 2 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: passo 6, immagine 2 di 2
    • Use tweezers to gently pull up the second speaker.
  7. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: passo 7, immagine 1 di 1
    • Remove and replace the speakers.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 3-4, Passmore Fall 2016 Membro di USF Tampa, Team 3-4, Passmore Fall 2016
USFT-PASSMORE-F16S3G4
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,351
