Salta al contenuto principale
Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement
Cosa ti serve
  1. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement, Motherboard: passo 1, immagine 1 di 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement, Motherboard: passo 1, immagine 2 di 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement, Motherboard: passo 1, immagine 3 di 3
    • Wedge your plastic opening tool into the crevice between the volume button and casing to create space.
    • Slide the plastic opening tool along this crevice to pry apart the backing of the tablet.
  2. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: passo 2, immagine 1 di 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: passo 2, immagine 2 di 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: passo 2, immagine 3 di 3
    • There are four zero insertion force connectors that need to be removed.
    • Use your plastic opening tool to flip up the black clips that secure the ribbon cables to the motherboard.
    • Once the clips are flipped up, the ribbon cables will be safe to remove.
  3. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: passo 3, immagine 1 di 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: passo 3, immagine 2 di 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: passo 3, immagine 3 di 3
    • Use your plastic opening tool to pry up and lift the antenna cables from the motherboard.
    • The connectors are delicate so use a gentle touch when prying them.
  4. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: passo 4, immagine 1 di 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: passo 4, immagine 2 di 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: passo 4, immagine 3 di 3
    • To remove the four bundle cable connectors, push against the edges of the connector to loosen it up.
    • Pull the cable away from the connector.
  5. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: passo 5, immagine 1 di 2 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: passo 5, immagine 2 di 2
    • Use your screwdriver with the Phillips PH000 attachment to remove the three 4mm screws.
    • Remove the motherboard from the tablet.
Conclusione
Altre 9 persone hanno completato questa guida.
USF Tampa, Team 3-4, Passmore Fall 2016 Membro di USF Tampa, Team 3-4, Passmore Fall 2016
USFT-PASSMORE-F16S3G4
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 23
Tutti i Tempi: 7,357
