Salta al contenuto principale
Acer Aspire S7-392-6484 LCD Replacement
Cosa ti serve
  1. Acer Aspire S7-392-6484 LCD Replacement, LCD: passo 1, immagine 1 di 2 Acer Aspire S7-392-6484 LCD Replacement, LCD: passo 1, immagine 2 di 2
    • Use a heat gun to heat the edges of the screen, loosening the adhesive underneath.
    • Run a jimmy or similarly thin object around the edge of the screen.
    • Using a suction cup, lift up on the screen to separate it from the adhesive.
    • Be aware that the screen will most likely crack significantly during these steps. Be prepared to immediately replace the LCD should you undertake this repair.
  2. Acer Aspire S7-392-6484 LCD Replacement: passo 2, immagine 1 di 2 Acer Aspire S7-392-6484 LCD Replacement: passo 2, immagine 2 di 2
    • Turn over the display to show the connectors underneath.
    • Disconnect the marked connectors to remove the display from the casing.
Conclusione
Nicholas Wise
Membro da: 02/14/18
754 Reputazione
5 Guide realizzate
USF Tampa, Team S2-G6, Eyestone Spring 2018 Membro di USF Tampa, Team S2-G6, Eyestone Spring 2018
USFT-EYESTONE-S18S2G6
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,706
