Salta al contenuto principale
Acer Aspire S7-392-6484 Solid State Drive Replacement
Cosa ti serve
  1. Acer Aspire S7-392-6484 Solid State Drive Replacement, Fan: passo 1, immagine 1 di 2 Acer Aspire S7-392-6484 Solid State Drive Replacement, Fan: passo 1, immagine 2 di 2
    • Remove the back panel by unscrewing all marked 3mm screws with a T6 Torx screwdriver.
    • Remove these screws with a T6 Torx screwdriver, but note that these feet screws are 4mm in length.
  2. Acer Aspire S7-392-6484 Solid State Drive Replacement: passo 2, immagine 1 di 2 Acer Aspire S7-392-6484 Solid State Drive Replacement: passo 2, immagine 2 di 2
    • Unscrew the marked 2mm screws with a Phillips #01 screwdriver.
    • Remove the fan by disconnecting the marked tabs.
  3. Acer Aspire S7-392-6484 Solid State Drive Replacement, Solid State Drive: passo 3, immagine 1 di 1
    • Remove the marked 2mm screw with a Phillips #01 screwdriver.
  4. Acer Aspire S7-392-6484 Solid State Drive Replacement: passo 4, immagine 1 di 1
    • Remove the hard drive by pulling it away horizontally from its connection.
Conclusione
Altre 3 persone hanno completato questa guida.
Nicholas Wise
Membro da: 02/14/18
754 Reputazione
5 Guide realizzate
USF Tampa, Team S2-G6, Eyestone Spring 2018 Membro di USF Tampa, Team S2-G6, Eyestone Spring 2018
USFT-EYESTONE-S18S2G6
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 2,593
