Salta al contenuto principale
Introduzione
The fan often needs replacement if the device is overheating or making loud noises while running. Some common tools will be needed for this replacement, such as a T6 Torx screwdriver and a Phillips #01 screwdriver. To determine if the fan needs to be replaced, please refer to this device's troubleshooting page.
Parti
Nessuna parte specificata.
  1. Remove the back panel by unscrewing all marked 3mm screws with a T6 Torx screwdriver. Remove these screws with a T6 Torx screwdriver, but note that these feet screws are 4mm in length.
    • Remove the back panel by unscrewing all marked 3mm screws with a T6 Torx screwdriver.
    • Remove these screws with a T6 Torx screwdriver, but note that these feet screws are 4mm in length.
  2. Batterie per PC portatili
    Una soluzione semplice per un grande aumento di potenza.
    Acquista ora
    Acquista ora
  3. Unscrew the marked 2mm screws with a Phillips #01 screwdriver. Remove the fan by disconnecting the marked tabs.
    • Unscrew the marked 2mm screws with a Phillips #01 screwdriver.
    • Remove the fan by disconnecting the marked tabs.
Conclusione
Nicholas Wise
Membro da: 14/02/2018
595 Reputazione
5 Guide realizzate
USF Tampa, Team S2-G6, Eyestone Spring 2018 Membro di USF Tampa, Team S2-G6, Eyestone Spring 2018
USFT-EYESTONE-S18S2G6
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 125
