Salta al contenuto principale
Acer Aspire S7-392-6484 Battery Replacement
Cosa ti serve
  1. Acer Aspire S7-392-6484 Battery Replacement, Battery: passo 1, immagine 1 di 2 Acer Aspire S7-392-6484 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Remove all marked 3mm screws from the back panel of the device using a T6 Torx screwdriver.
    • Remove the orange marked screws using a T6 Torx screwdriver. Note that these screws are 4mm in length.
    • After all marked screws have been removed, lift up back panel to expose internal parts.
  2. Acer Aspire S7-392-6484 Battery Replacement: passo 2, immagine 1 di 1
    • Unscrew the marked 1.5 mm screws with a Phillips #01 screwdriver.
  3. Acer Aspire S7-392-6484 Battery Replacement: passo 3, immagine 1 di 1
    • Disconnect the cable located at the top of the battery. Be careful to pull the cable horizontally, not vertically.
  4. Acer Aspire S7-392-6484 Battery Replacement: passo 4, immagine 1 di 1
    • Remove the battery.
Conclusione
Nicholas Wise
Membro da: 02/14/18
754 Reputazione
5 Guide realizzate
USF Tampa, Team S2-G6, Eyestone Spring 2018 Membro di USF Tampa, Team S2-G6, Eyestone Spring 2018
USFT-EYESTONE-S18S2G6
3 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 36
Tutti i Tempi: 5,619
