Salta al contenuto principale
Acer Aspire S3 MS2346 Keyboard Replacement
Cosa ti serve
  1. Acer Aspire S3 MS2346 Keyboard Replacement, Back Cover: passo 1, immagine 1 di 3 Acer Aspire S3 MS2346 Keyboard Replacement, Back Cover: passo 1, immagine 2 di 3 Acer Aspire S3 MS2346 Keyboard Replacement, Back Cover: passo 1, immagine 3 di 3
    • Remove the 12 5mm Phillips #00 screws.
    • Use a plastic opening tool to gently pry open the back panel.
    • Gently lift up the back panel, exposing the internals of the laptop.
  2. Acer Aspire S3 MS2346 Keyboard Replacement, Motherboard: passo 2, immagine 1 di 3 Acer Aspire S3 MS2346 Keyboard Replacement, Motherboard: passo 2, immagine 2 di 3 Acer Aspire S3 MS2346 Keyboard Replacement, Motherboard: passo 2, immagine 3 di 3
    • Remove the motherboard connector cables by gently lifting the black latch that clamps them in place with a spudger or simply pull the connector from the port.
  3. Acer Aspire S3 MS2346 Keyboard Replacement: passo 3, immagine 1 di 2 Acer Aspire S3 MS2346 Keyboard Replacement: passo 3, immagine 2 di 2
    • Remove the 5 5mm PH0 screws holding the motherboard in place.
    • Gently remove the motherboard from the chassis.
  4. Acer Aspire S3 MS2346 Keyboard Replacement: passo 4, immagine 1 di 1
    • Gently remove the motherboard.
  5. Acer Aspire S3 MS2346 Keyboard Replacement, Speakers: passo 5, immagine 1 di 2 Acer Aspire S3 MS2346 Keyboard Replacement, Speakers: passo 5, immagine 2 di 2
    • Unscrew the 4 1mm PH00 screws attaching the speakers to the frame.
  6. Acer Aspire S3 MS2346 Keyboard Replacement: passo 6, immagine 1 di 1
    • Gently remove the speakers. Note that the wire connecting them may be lightly glued down. If so, gently pry up.
  7. Acer Aspire S3 MS2346 Keyboard Replacement, Battery: passo 7, immagine 1 di 1
    • Gently lift the battery from the frame.
  8. Acer Aspire S3 MS2346 Keyboard Replacement, Keyboard: passo 8, immagine 1 di 3 Acer Aspire S3 MS2346 Keyboard Replacement, Keyboard: passo 8, immagine 2 di 3 Acer Aspire S3 MS2346 Keyboard Replacement, Keyboard: passo 8, immagine 3 di 3
    • The 30 1mm PH000 screws holding the keyboard in place will be distributed all over the back.
    • You will need to gently pry up the black tape to expose the remaining screws.
  9. Acer Aspire S3 MS2346 Keyboard Replacement: passo 9, immagine 1 di 1
    • Gently lift the board exposing the keyboard assembly.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,484
