Salta al contenuto principale
Acer Aspire S3 MS2346 Display Assembly Replacement
Cosa ti serve
  1. Acer Aspire S3 MS2346 Display Assembly Replacement, Back Cover: passo 1, immagine 1 di 3 Acer Aspire S3 MS2346 Display Assembly Replacement, Back Cover: passo 1, immagine 2 di 3 Acer Aspire S3 MS2346 Display Assembly Replacement, Back Cover: passo 1, immagine 3 di 3
    • Remove the 12 5mm Phillips #00 screws.
    • Use a plastic opening tool to gently pry open the back panel.
    • Gently lift up the back panel, exposing the internals of the laptop.
  2. Acer Aspire S3 MS2346 Display Assembly Replacement, Motherboard: passo 2, immagine 1 di 3 Acer Aspire S3 MS2346 Display Assembly Replacement, Motherboard: passo 2, immagine 2 di 3 Acer Aspire S3 MS2346 Display Assembly Replacement, Motherboard: passo 2, immagine 3 di 3
    • Remove the motherboard connector cables by gently lifting the black latch that clamps them in place with a spudger or simply pull the connector from the port.
  3. Acer Aspire S3 MS2346 Display Assembly Replacement: passo 3, immagine 1 di 2 Acer Aspire S3 MS2346 Display Assembly Replacement: passo 3, immagine 2 di 2
    • Remove the 5 5mm PH0 screws holding the motherboard in place.
    • Gently remove the motherboard from the chassis.
  4. Acer Aspire S3 MS2346 Display Assembly Replacement: passo 4, immagine 1 di 1
    • Gently remove the motherboard.
  5. Acer Aspire S3 MS2346 Display Assembly Replacement, Display Assembly: passo 5, immagine 1 di 2 Acer Aspire S3 MS2346 Display Assembly Replacement, Display Assembly: passo 5, immagine 2 di 2
    • Unscrew the 10 5mm PH00 screws from the hinges attaching the display assembly to the base.
  6. Acer Aspire S3 MS2346 Display Assembly Replacement: passo 6, immagine 1 di 1
    • Unlatch the screen from the frame
Conclusione
Altre 3 persone hanno completato questa guida.
3 Commenti
Hey where can I find the screen for this model, cause currently my laptop screen backlight spoiled.
Harry joel - Replica
You can find this screen on 3rd party sites such as newegg and ebay.
Stacy Schauls -
Please arrange me a screen for this acer aspire S3 ms 2346
Amit Gangwar - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 26
Tutti i Tempi: 3,100
