Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
This guide will walk you through accessing the battery. The battery may need be accessed for replacement or repair. Be careful not to puncture or damage the battery, and dispose of it immediately if it begins to heat up while disconnected.
Parti
Nessuna parte specificata.
  1. Remove the 12 5mm Phillips #00 screws. Use a plastic opening tool to gently pry open the back panel. Gently lift up the back panel, exposing the internals of the laptop.
    • Remove the 12 5mm Phillips #00 screws.
    • Use a plastic opening tool to gently pry open the back panel.
    • Gently lift up the back panel, exposing the internals of the laptop.
  2. Unscrew the 4 1mm PH00 screws attaching the speakers to the frame. Unscrew the 4 1mm PH00 screws attaching the speakers to the frame.
    • Unscrew the 4 1mm PH00 screws attaching the speakers to the frame.
  3. Gently remove the speakers. Note that the wire connecting them may be lightly glued down. If so, gently pry up.
    • Gently remove the speakers. Note that the wire connecting them may be lightly glued down. If so, gently pry up.
  4. Gently lift the battery from the frame.
    • Gently lift the battery from the frame.
Conclusione
Altre 2 persone hanno completato questa guida.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 117
Tutti i Tempi: 1,392
