Salta al contenuto principale
Acer Aspire R7 Speakers Replacement
Cosa ti serve
  1. Acer Aspire R7 Speakers Replacement, Cover: passo 1, immagine 1 di 1
    • Shut down the laptop and disconnect the power cord.
    • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
    • Turn the laptop over.
  2. Acer Aspire R7 Speakers Replacement: passo 2, immagine 1 di 3 Acer Aspire R7 Speakers Replacement: passo 2, immagine 2 di 3 Acer Aspire R7 Speakers Replacement: passo 2, immagine 3 di 3
    • Remove seven 10 mm T7 screws.
    • Remove four 6 mm T7 screws.
    • Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
    • Remove the remaining four 10 mm T7 screws.
  3. Acer Aspire R7 Speakers Replacement: passo 3, immagine 1 di 1
    • Carefully lift the cover upwards.
    • If the cover seems stuck, use a spudger tool to pry the sides.
  4. Acer Aspire R7 Speakers Replacement, Speakers: passo 4, immagine 1 di 2 Acer Aspire R7 Speakers Replacement, Speakers: passo 4, immagine 2 di 2
    • Locate the clip attaching the right-side speakers to the motherboard.
    • Carefully pull on the clip until it detaches from the motherboard.
    • Use a plastic opening tool if needed.
  5. Acer Aspire R7 Speakers Replacement: passo 5, immagine 1 di 2 Acer Aspire R7 Speakers Replacement: passo 5, immagine 2 di 2
    • Remove the two 3.5mm #00 Phillips screws which hold the speaker in place.
    • Carefully lift the right-side speaker assembly away from the motherboard.
  6. Acer Aspire R7 Speakers Replacement: passo 6, immagine 1 di 2 Acer Aspire R7 Speakers Replacement: passo 6, immagine 2 di 2
    • Locate the clip attaching the left-side speakers to the motherboard.
  7. Acer Aspire R7 Speakers Replacement: passo 7, immagine 1 di 2 Acer Aspire R7 Speakers Replacement: passo 7, immagine 2 di 2
    • Carefully lift the left-side speaker assembly away from the motherboard.
Conclusione
Andrew Rodiek
Membro da: 01/13/15
601 Reputazione
4 Guide realizzate
USF Tampa, Team 3-4, Hickman Winter 2015 Membro di USF Tampa, Team 3-4, Hickman Winter 2015
USFT-HICKMAN-W15S3G4
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 722
