Salta al contenuto principale
Acer Aspire R7 Battery Replacement
Cosa ti serve
  1. Acer Aspire R7 Battery Replacement, Cover: passo 1, immagine 1 di 1
    • Shut down the laptop and disconnect the power cord.
    • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
    • Turn the laptop over.
    Use the blue plastic opening tool to carefully remove the rubber pad which covers the one remaining screw.
    Picture shows the rubber pad removed but srew to be removed is not indicated
    Anthymoine - Replica
  2. Acer Aspire R7 Battery Replacement: passo 2, immagine 1 di 3 Acer Aspire R7 Battery Replacement: passo 2, immagine 2 di 3 Acer Aspire R7 Battery Replacement: passo 2, immagine 3 di 3
    • Remove seven 10 mm T7 screws.
    • Remove four 6 mm T7 screws.
    • Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
    • Remove the remaining four 10 mm T7 screws.
    Step 2 is missing the 1 (10mm T-7 ) screw that is under a rubber pad in the bottom middle of the laptop. The picture shows this pad and screw already missing. Note the silver color instead of the black color of the rest of the bottom of the laptop.
    Daniel Flynn - Replica
  3. Acer Aspire R7 Battery Replacement: passo 3, immagine 1 di 1
    • Carefully lift the cover upwards.
    • If the cover seems stuck, use a spudger tool to pry the sides.
  4. Acer Aspire R7 Battery Replacement, Battery: passo 4, immagine 1 di 2 Acer Aspire R7 Battery Replacement, Battery: passo 4, immagine 2 di 2
    • Locate the battery ribbon connector
    • Remove the ribbon cable attaching the battery to the motherboard by carefully pulling it outwards
    • When using the spudger be careful around the motherboard as it can easily be damaged
  5. Acer Aspire R7 Battery Replacement: passo 5, immagine 1 di 3 Acer Aspire R7 Battery Replacement: passo 5, immagine 2 di 3 Acer Aspire R7 Battery Replacement: passo 5, immagine 3 di 3
    • Remove the three 4.5mm #00 Phillips screws attaching the battery to the motherboard
    • Push the 4 retaining clips away from the battery
    • Carefully lift the battery from the motherboard
Conclusione
Altre 12 persone hanno completato questa guida.
F Fernandez
Membro da: 01/13/15
435 Reputazione
2 Guide realizzate
USF Tampa, Team 3-4, Hickman Winter 2015 Membro di USF Tampa, Team 3-4, Hickman Winter 2015
USFT-HICKMAN-W15S3G4
4 Membri
7 Guide realizzate
6 Commenti
great instructions
amaryheart7777777 - Replica
What is the battery reference for replacement ?
skalpinou - Replica
which battery model do I purchase for replacing on an Acer Aspire R?
Eddie - Replica
hey how do you want då sel it for
Alex santos - Replica
super tuto
Thanks
P.S : A have add a short comment on step 2.
Bests regards
thank you for your help.
paul cowley - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 36
Tutti i Tempi: 41,168
