Salta al contenuto principale
Acer Aspire R7 AC Socket Replacement
Cosa ti serve
  1. Acer Aspire R7 AC Socket Replacement, Cover: passo 1, immagine 1 di 1
    • Shut down the laptop and disconnect the power cord.
    • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
    • Turn the laptop over.
  2. Acer Aspire R7 AC Socket Replacement: passo 2, immagine 1 di 3 Acer Aspire R7 AC Socket Replacement: passo 2, immagine 2 di 3 Acer Aspire R7 AC Socket Replacement: passo 2, immagine 3 di 3
    • Remove six 6mm T7 screws.
    • Remove four 4mm T7 screws.
    • Remove two 10mm T7 screws
    • Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
    • Remove the remaining two10mm T7 screws.
  3. Acer Aspire R7 AC Socket Replacement: passo 3, immagine 1 di 1
    • Carefully lift the cover upwards.
    • If the cover seems stuck, use a spudger tool to pry the sides.
  4. Acer Aspire R7 AC Socket Replacement, AC Socket: passo 4, immagine 1 di 3 Acer Aspire R7 AC Socket Replacement, AC Socket: passo 4, immagine 2 di 3 Acer Aspire R7 AC Socket Replacement, AC Socket: passo 4, immagine 3 di 3
    • Locate the AC Socket ribbon connector
    • Loosen the ribbon connector using the plastic opening tool
    • Pull the ribbon connector away from the motherboard
  5. Acer Aspire R7 AC Socket Replacement: passo 5, immagine 1 di 2 Acer Aspire R7 AC Socket Replacement: passo 5, immagine 2 di 2
    • Use the plastic opening tool to pry up on the yellow tabs holding the Socket in place
    • There is two sided tape holding this component to the case
    • Once the tape on the Socket is loose, pull up and away from the case to remove it.
Conclusione
Andrew Rodiek
Membro da: 01/13/15
601 Reputazione
4 Guide realizzate
USF Tampa, Team 3-4, Hickman Winter 2015 Membro di USF Tampa, Team 3-4, Hickman Winter 2015
USFT-HICKMAN-W15S3G4
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 24
Tutti i Tempi: 1,475
