Salta al contenuto principale
Acer Aspire R5-571T-59DC RAM Replacement
Cosa ti serve
  1. Acer Aspire R5-571T-59DC RAM Replacement, Back Cover Panel: passo 1, immagine 1 di 2 Acer Aspire R5-571T-59DC RAM Replacement, Back Cover Panel: passo 1, immagine 2 di 2
    • Disconnect all power from the laptop and turn over so the bottom is facing you.
    • Remove the twelve 07.mm Phillips #0 screws from the back cover.
    • Work a plastic opening tool underneath and around the perimeter of the bottom cover.
    • Once unclipped, remove the bottom cover.
  2. Acer Aspire R5-571T-59DC RAM Replacement, RAM: passo 2, immagine 1 di 1
    • Lift up the protective covering away from the RAM using tweezers, or your fingers.
  3. Acer Aspire R5-571T-59DC RAM Replacement: passo 3, immagine 1 di 3 Acer Aspire R5-571T-59DC RAM Replacement: passo 3, immagine 2 di 3 Acer Aspire R5-571T-59DC RAM Replacement: passo 3, immagine 3 di 3
    • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
    • When released, the RAM module will pop up at a slight angle.
    • Lift the RAM module to an angle of about 30 degrees and slide it out.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team S20-G2, Passmore Spring 2018 Membro di USF Tampa, Team S20-G2, Passmore Spring 2018
USFT-PASSMORE-S18S20G2
3 Membri
7 Guide realizzate
Un commento
How many slots for RAM does this laptop have? Is there a soldered stick in one of the slots? Thanks!
Alberto Einsteino - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 954
