Salta al contenuto principale
Acer Aspire R5-571T-59DC Battery Replacement
Cosa ti serve
  1. Acer Aspire R5-571T-59DC Battery Replacement, Back Cover Panel: passo 1, immagine 1 di 2 Acer Aspire R5-571T-59DC Battery Replacement, Back Cover Panel: passo 1, immagine 2 di 2
    • Disconnect all power from the laptop and turn over so the bottom is facing you.
    • Remove the twelve 07.mm Phillips #0 screws from the back cover.
    • Work a plastic opening tool underneath and around the perimeter of the bottom cover.
    • Once unclipped, remove the bottom cover.
  2. Acer Aspire R5-571T-59DC Battery Replacement, Battery: passo 2, immagine 1 di 3 Acer Aspire R5-571T-59DC Battery Replacement, Battery: passo 2, immagine 2 di 3 Acer Aspire R5-571T-59DC Battery Replacement, Battery: passo 2, immagine 3 di 3
    • Remove the two 0.7mm Phillips #00 screws from the battery and unplug the battery from the motherboard.
    • Lift the battery out of the case.
Conclusione
USF Tampa, Team S20-G2, Passmore Spring 2018 Membro di USF Tampa, Team S20-G2, Passmore Spring 2018
USFT-PASSMORE-S18S20G2
3 Membri
7 Guide realizzate
Un commento
This seems to be the correct battery for the replacement, judging by the above photos, the AC14B3K
Acer AC14B3K, AC14B8J, and AC14B8K Laptop Battery
I plan to try this repair myself soon.
Sean Anderson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 5,120
