Introduzione
This guide will show the reader how to remove the back panel from their Acer Aspire R5-571T-59DC.
Be sure to be gentle opening the inner snaps around the lining of the cover - gently running a credit card or spudger around the inside of the lining should be sufficient to loosen the cover.
This is a prerequisite step to replacing any component connected to the motherboard.
Cosa ti serve
Disconnect all power from the laptop and turn over so the bottom is facing you.
Remove the twelve 07.mm Phillips #0 screws from the back cover.
Work a plastic opening tool underneath and around the perimeter of the bottom cover.
Once unclipped, remove the bottom cover.
