Salta al contenuto principale
Acer Aspire R5-471T-52EE Screen Replacement
Cosa ti serve
  1. Acer Aspire R5-471T-52EE Screen Replacement, Back Cover: passo 1, immagine 1 di 2 Acer Aspire R5-471T-52EE Screen Replacement, Back Cover: passo 1, immagine 2 di 2
    • Unplug the laptop and turn it off.
    • Remove the twelve 3mm screws using the Phillips #1 screwdriver.
  2. Acer Aspire R5-471T-52EE Screen Replacement: passo 2, immagine 1 di 1
    • With the hinges of the laptop pointing away from you, gently begin to pull on the portion between the two hinges towards yourself until you feel the cover pop off.
    • Remove the back cover from the device.
  3. Acer Aspire R5-471T-52EE Screen Replacement, Screen: passo 3, immagine 1 di 1
    • Disconnect the three wires from the motherboard that connect to the screen.
    • Be very gentle when removing these wires as the connections with the motherboard are delicate.
  4. Acer Aspire R5-471T-52EE Screen Replacement: passo 4, immagine 1 di 1
    • Remove the eight 3mm screws on the hinges using the Phillips #1 screwdriver.
    • Now that the hinges have been unfastened, carefully separate the screen and screen casing from the other half of the computer.
  5. Acer Aspire R5-471T-52EE Screen Replacement: passo 5, immagine 1 di 2 Acer Aspire R5-471T-52EE Screen Replacement: passo 5, immagine 2 di 2
    • Using a spudger or an opening pick, pop open the case holding the screen. Follow the line where the two pieces of the case meet all around the screen.
    • Remove the display assembly from the device.
Conclusione
To install the screen and reassemble your device, follow these instructions in reverse order.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 12
Tutti i Tempi: 354
