Salta al contenuto principale
Acer Aspire R5-471T-52EE Back Cover Replacement
Cosa ti serve
  1. Acer Aspire R5-471T-52EE Back Cover Replacement, Back Cover: passo 1, immagine 1 di 2 Acer Aspire R5-471T-52EE Back Cover Replacement, Back Cover: passo 1, immagine 2 di 2
    • Unplug the laptop and turn it off.
    • Remove the twelve 3mm screws using the Phillips #1 screwdriver.
  2. Acer Aspire R5-471T-52EE Back Cover Replacement: passo 2, immagine 1 di 1
    • With the hinges of the laptop pointing away from you, gently begin to pull on the portion between the two hinges towards yourself until you feel the cover pop off.
    • Remove the back cover from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 8
Tutti i Tempi: 161
