Introduzione
This guide will give you step-by-step instructions on how to safely and successfully remove the RAM from your Acer Aspire R11 R3-131T-C1Z5.
Cosa ti serve
Flip the laptop on to its front, so that the back is facing up
Unscrew the twelve 19.05 mm PH#0 screws.
Attrezzo utilizzato in questo passaggio:Anti-Static Wrist Strap$7.95
Connect the clip of an anti-static wrist strap to any piece of metal on the computer.
Locate the large silver rectangle to the right of the hard drive. This is where your ram is located.
Altre 2 persone hanno completato questa guida.
4 Commenti
can u remove ram without removing battery ?
no, you can’t if you don’t remove the battery you will probably get shocked if you don’t remove the battery I highly recommend removing the battery
Thanks to this site; always a life saver
I replace my 2GB of RAM to 4GB of RAM it’s much faster but the computer does not have an HD or SSD and my is a different model
