Salta al contenuto principale
Acer Aspire R11 R3-131T-C1Z5 Hard drive Replacement
Cosa ti serve
  1. Acer Aspire R11 R3-131T-C1Z5 Hard drive  Replacement, Hard drive: passo 1, immagine 1 di 2 Acer Aspire R11 R3-131T-C1Z5 Hard drive  Replacement, Hard drive: passo 1, immagine 2 di 2
    • Flip the laptop over on its front, so that the back is facing up.
    • Unscrew the twelve 19.05 mm PH#0 screws.
  2. Acer Aspire R11 R3-131T-C1Z5 Hard drive  Replacement: passo 2, immagine 1 di 2 Acer Aspire R11 R3-131T-C1Z5 Hard drive  Replacement: passo 2, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    Compra
    • At the left front corner of the laptop, under the intel sticker, press the sharp end of a metal spudger between the keyboard and the back cover to pry it apart.
    • It is important to ground yourself to avoid static.
    • Put on an anti-static wrist strap and connect the metal clip at the other end to any piece of metal you can identify on the laptop.
  3. Acer Aspire R11 R3-131T-C1Z5 Hard drive  Replacement: passo 3, immagine 1 di 3 Acer Aspire R11 R3-131T-C1Z5 Hard drive  Replacement: passo 3, immagine 2 di 3 Acer Aspire R11 R3-131T-C1Z5 Hard drive  Replacement: passo 3, immagine 3 di 3
    • Locate the big silver aluminum square on the left side of the back of the laptop. This is the hard drive to the computer.
    • Remove the two 12.7 mm PH#0 screws.
  4. Acer Aspire R11 R3-131T-C1Z5 Hard drive  Replacement: passo 4, immagine 1 di 3 Acer Aspire R11 R3-131T-C1Z5 Hard drive  Replacement: passo 4, immagine 2 di 3 Acer Aspire R11 R3-131T-C1Z5 Hard drive  Replacement: passo 4, immagine 3 di 3
    • Lift and disconnect right flap of the white ribbon that runs across the hard Drive.
    • Detach the cable that is located right where you disconnected the ribbon.
    • Remove the Hard Drive
Conclusione
Altre 9 persone hanno completato questa guida.
4 Commenti
What do I do if there isn’t a hard drive in there? It says it has a 36GB SSD eMMC Form Factor internal storage, but the HDD rack/mount is empty.
Thanks!
Dan - Replica
Okay………………after I perform the above steps, what happens? Power up and all is well? How much “HDD” space do I then have? There is no parts list. Will I need some sort of external drive? When I finish this, I would like to have at least 80G of storage space. More if possible. Please reply to <<n4ctf@hotmail.com>> Thanks to all
Boog Moore - Replica
Opened the computer and found all of the above. I have a 500Gb SSD purchased from Crucial Memory. There is no way to connect this SSD as it stands now. Do I need to purchase some kind of adapter? Is there a connector to be soldered to the mother board? I upgraded the RAM to 8Gb. TREMENDOUS improvement. Even tried installing apps/programs to an external drive. It all worked OK but not that much of an increase in internal storage. I don’t need a bunch of statements. I need a solution or direct me to where I can obtain a fix. Thanks
For the unlucky users (like me) with the eMMC version, you can install a SATA drive only if you solder the missing components on the motherboard and buy the missing SATA cable. I found this article where they successfully added a HD, with the parts list. Only 4 capacitors and a connector is missing, but they are SMD ones, good soldering skills needed.
wfbook - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 48
Tutti i Tempi: 12,686
