Salta al contenuto principale
Acer Aspire R R5-471T-51UN Battery Replacement
Cosa ti serve
  1. Acer Aspire R R5-471T-51UN Battery Replacement, Battery: passo 1, immagine 1 di 3 Acer Aspire R R5-471T-51UN Battery Replacement, Battery: passo 1, immagine 2 di 3 Acer Aspire R R5-471T-51UN Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Flip your laptop over so the bottom is facing you.
    • Remove the twelve 5 mm screws with a Phillips #0 screwdriver.
  2. Acer Aspire R R5-471T-51UN Battery Replacement: passo 2, immagine 1 di 3 Acer Aspire R R5-471T-51UN Battery Replacement: passo 2, immagine 2 di 3 Acer Aspire R R5-471T-51UN Battery Replacement: passo 2, immagine 3 di 3
    • Insert the Jimmy between the back cover of the laptop and the base of the laptop and then slowly use the Jimmy to pry off the back cover of the laptop.
  3. Acer Aspire R R5-471T-51UN Battery Replacement: passo 3, immagine 1 di 2 Acer Aspire R R5-471T-51UN Battery Replacement: passo 3, immagine 2 di 2
    • Use your Phillips #0 screwdriver to remove the two 3mm screws on the battery.
  4. Acer Aspire R R5-471T-51UN Battery Replacement: passo 4, immagine 1 di 3 Acer Aspire R R5-471T-51UN Battery Replacement: passo 4, immagine 2 di 3 Acer Aspire R R5-471T-51UN Battery Replacement: passo 4, immagine 3 di 3
    • Gently and cautiously pinch the white ends of the battery connector cable and slowly pull it from the motherboard.
  5. Acer Aspire R R5-471T-51UN Battery Replacement: passo 5, immagine 1 di 2 Acer Aspire R R5-471T-51UN Battery Replacement: passo 5, immagine 2 di 2
    • Gently lift the battery out of the laptop.
    • Be cautious with the lithium ion battery as you remove it.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,044
