Salta al contenuto principale
Acer Aspire One ZG5 Wireless Card Replacement
Cosa ti serve
  1. Acer Aspire One ZG5 Wireless Card Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the netbook upside down with the battery at the top, facing away from you.
  2. Acer Aspire One ZG5 Wireless Card Replacement: passo 2, immagine 1 di 1
    • Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
  3. Acer Aspire One ZG5 Wireless Card Replacement: passo 3, immagine 1 di 1
    • Slide the latch located on the opposite hinge from the lock while pushing the battery up.
  4. Acer Aspire One ZG5 Wireless Card Replacement, Wireless Card: passo 4, immagine 1 di 1
    • Gently loosen the two Phillips #0 screws in the small panel that covers the wireless card.
    • These screws are built into the panel and aren't meant to be completely removed.
  5. Acer Aspire One ZG5 Wireless Card Replacement: passo 5, immagine 1 di 1
    • Lift up the panel and remove it from the case.
  6. Acer Aspire One ZG5 Wireless Card Replacement: passo 6, immagine 1 di 1
    • Disconnect the two antenna cables from the left side of the wireless card.
  7. Acer Aspire One ZG5 Wireless Card Replacement: passo 7, immagine 1 di 1
    • Remove the single 3.9 mm Phillips #1 screw from the bottom left of the wireless card.
  8. Acer Aspire One ZG5 Wireless Card Replacement: passo 8, immagine 1 di 1
    • Gently lift up the left side of the wireless card and slide the card out of its socket.
Conclusione
Altre 8 persone hanno completato questa guida.
Doug Gallatin
Membro da: 10/05/10
6.337 Reputazione
10 Guide realizzate
Cal Poly, Team 7-49, Amido Fall 2010 Membro di Cal Poly, Team 7-49, Amido Fall 2010
CPSU-AMIDO-F10S7G49
5 Membri
27 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 24
Tutti i Tempi: 23,539
