Introduzione
There are screws and several cables that need to be removed before the top case will come off. The battery and the keyboard both need to be removed as well.
Cosa ti serve
Turn the netbook upside down with the battery at the top, facing away from you.
Gently loosen the two Phillips #0 screws in the small panel that covers the wireless card.
Turn the netbook over and open the display so that the keyboard is facing you.
Close the display and turn the ZG5 over so that the battery compartment faces away from you.
Altre 6 persone hanno completato questa guida.
