Salta al contenuto principale
Acer Aspire One P1VE6 Back Panel Replacement
Cosa ti serve
  1. Acer Aspire One P1VE6 Back Panel Replacement, Back Panel: passo 1, immagine 1 di 1
    • Close the netbook and turn it over so the back panel faces you.
  2. Acer Aspire One P1VE6 Back Panel Replacement: passo 2, immagine 1 di 1
    • Locate the 4 mm Phillips #1 screw at the bottom of the back panel. Using the Phillips head screwdriver, remove the screw. Place the screw somewhere it will not be lost. Then remove the back panel by gently sliding it towards the front.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 956
