Introduzione
Describes how to remove the keyboard.
Cosa ti serve
Open the lid othe the netbook. Use the Jimmy from the upper left corner of the keyboard. Put it between the keyboard and th casing and move it to the right. It might help to use a metal spudger to push in the pins holding the keyboard in place.
Then move down along the sides where there is one pin on each side. After that twist the keyboard towards you.
Now open the brown connector so the flat cable is loose. Then you can remove the keyboard.
Lets see, the most delicate operation of all- flexible flat cable removal- and you say open it till loose. How ? Is the type of retainer that moves backwards, flips up or has side clips. Guess wrong and you are buying a new motherboard. Of course that could be the point of the ommission
Altre 5 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
