Introduzione
Describes how you replace the HDD from the netbook.
Cosa ti serve
Open the lid othe the netbook. Use the Jimmy from the upper left corner of the keyboard. Put it between the keyboard and th casing and move it to the right. It might help to use a metal spudger to push in the pins holding the keyboard in place.
Then move down along the sides where there is one pin on each side. After that twist the keyboard towards you.
Use a spudger or flat screwdriver to push down the hatch where it is marked "Door release".
Now you can carfully remove the hatch.
When reassembling the hatch look that the noses are aimed at the appropriate holes in the case, then you can press down the rest of the hatch onto the netbook.
The hard disk drive is under the lighgrey casing and not screw to it.
Altre 7 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
7 Commenti
very helpful
many thanks
You are missing a few steps.
The HD is removed through the back - there are about 5 screws (marked "Door") that need to be removed once the keyboard is removed. :-)
Thanks for the feedback, I added the steps at least in the German Guide do not know how long it takes for the steps to show up in the translated English Version.
Claes -
