Salta al contenuto principale
Acer Aspire One D255E Keyboard Replacement
Cosa ti serve
  1. Acer Aspire One D255E Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Start by removing the battery found on the back of the device.
    • The battery must be removed in order to ensure the device does not have power! Make sure you do not skip this step!
  2. Acer Aspire One D255E Keyboard Replacement: passo 2, immagine 1 di 2 Acer Aspire One D255E Keyboard Replacement: passo 2, immagine 2 di 2
    • Using plastic opening tools press down the 6 clips located around the keyboard.
  3. Acer Aspire One D255E Keyboard Replacement: passo 3, immagine 1 di 3 Acer Aspire One D255E Keyboard Replacement: passo 3, immagine 2 di 3 Acer Aspire One D255E Keyboard Replacement: passo 3, immagine 3 di 3
    • Using a plastic opening tool or spudger move the keyboard out of position.
    • There is a thin cable on the backside of the keyboard. Make sure when you move the keyboard out of position you do so slowly to prevent damage to this cable.
    • If you use a spudger it is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
  4. Acer Aspire One D255E Keyboard Replacement: passo 4, immagine 1 di 1
    • Using a spudger gently push the tab on the port forward then pull out the cable.
    • Be careful to do so as gently as possible. You do not want to damage the port.
Conclusione
Altre 3 persone hanno completato questa guida.
Brian
Membro da: 03/19/16
1.248 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 32
Tutti i Tempi: 2,364
