Salta al contenuto principale
Acer Aspire One D255-1625 RAM Replacement
Cosa ti serve
  1. Acer Aspire One D255-1625 RAM Replacement, Battery: passo 1, immagine 1 di 3 Acer Aspire One D255-1625 RAM Replacement, Battery: passo 1, immagine 2 di 3 Acer Aspire One D255-1625 RAM Replacement, Battery: passo 1, immagine 3 di 3
    • Before you replace the battery, ensure that the device is unplugged and powered off.
    • Pull the upper left switch on the back of the laptop to the left into the unlock position.
    • Pull the upper right switch to the left and hold it in place.
  2. Acer Aspire One D255-1625 RAM Replacement: passo 2, immagine 1 di 1
    • Pull the battery straight out.
    • To properly dispose of battery, locate your nearest recycling plant to dispose of it there.
  3. Acer Aspire One D255-1625 RAM Replacement, RAM: passo 3, immagine 1 di 1
    • Use iFixit’s Jimmy tool to remove the bottom panel of the device.
    • Wedge the tool into the top middle of the panel until the back gently pops off.
  4. Acer Aspire One D255-1625 RAM Replacement: passo 4, immagine 1 di 3 Acer Aspire One D255-1625 RAM Replacement: passo 4, immagine 2 di 3 Acer Aspire One D255-1625 RAM Replacement: passo 4, immagine 3 di 3
    • Push the silver locking tabs on either side of the RAM card outward and the card will pop up to rest at an angle.
    • Slide the card straight out of its housing.
Conclusione
2 Commenti
I was lazy to do it the proper way and thought this was a short cut... Sadly the author is an a*** and doesn't show that there are two screws connected to the bottom plastic base. Well I ripped them right off. The right way is to remove the key board and then unscrew the two screws after that you can pop the bottom panel.
YuraD95 - Replica
Sorry I was wrong it's not 2 screws it was 5 screws that I ripped off.
YuraD95 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 13
Tutti i Tempi: 280
