Salta al contenuto principale
Acer Aspire One D255-1625 Keyboard Replacement
Cosa ti serve
  1. Acer Aspire One D255-1625 Keyboard Replacement, Battery: passo 1, immagine 1 di 3 Acer Aspire One D255-1625 Keyboard Replacement, Battery: passo 1, immagine 2 di 3 Acer Aspire One D255-1625 Keyboard Replacement, Battery: passo 1, immagine 3 di 3
    • Before you replace the battery, ensure that the device is unplugged and powered off.
    • Pull the upper left switch on the back of the laptop to the left into the unlock position.
    • Pull the upper right switch to the left and hold it in place.
  2. Acer Aspire One D255-1625 Keyboard Replacement: passo 2, immagine 1 di 1
    • Pull the battery straight out.
    • To properly dispose of battery, locate your nearest recycling plant to dispose of it there.
  3. Acer Aspire One D255-1625 Keyboard Replacement, Keyboard: passo 3, immagine 1 di 2 Acer Aspire One D255-1625 Keyboard Replacement, Keyboard: passo 3, immagine 2 di 2
    • Use iFixit's Jimmy tool and press it into the small tabs at the top of the keyboard and lift up.
    • Do this for all five tabs at the top of the keyboard.
  4. Acer Aspire One D255-1625 Keyboard Replacement: passo 4, immagine 1 di 1
    • Slide the Jimmy tool along the top of the keyboard once all tabs have been pressed in.
  5. Acer Aspire One D255-1625 Keyboard Replacement: passo 5, immagine 1 di 3 Acer Aspire One D255-1625 Keyboard Replacement: passo 5, immagine 2 di 3 Acer Aspire One D255-1625 Keyboard Replacement: passo 5, immagine 3 di 3
    • Flip the keyboard forward to expose its connection.
    • Slide the small brown tab out to disconnect the keyboard.
    • Lift the keyboard away from the laptop.
    • If you see that the keyboard is not connected upon flipping, reconnect it and see if it works. If not, continue to replace the keyboard.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 15
Tutti i Tempi: 272
