Salta al contenuto principale
Acer Aspire One D250-1151 Keyboard Key Replacement
Cosa ti serve
  1. Acer Aspire One D250-1151 Keyboard Key Replacement, Keyboard Key: passo 1, immagine 1 di 1
    • Open the Computer so you have access to the keyboard and the screen.
  2. Acer Aspire One D250-1151 Keyboard Key Replacement: passo 2, immagine 1 di 1
    • Do not apply too much force while removing the key or the edge under the key will be pushed down, preventing replacement.
    • Use the plastic opening tool to lift the key from the right side until it comes off.
    • You will hear a pop, this is normal. In some cases the inner plastic part of the key will also come off.
  3. Acer Aspire One D250-1151 Keyboard Key Replacement: passo 3, immagine 1 di 3 Acer Aspire One D250-1151 Keyboard Key Replacement: passo 3, immagine 2 di 3 Acer Aspire One D250-1151 Keyboard Key Replacement: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use the tweezers to remove the plastic brackets from the keyboard.
    • Picture two and three show the correct orientation of the plastic pieces and how they are connected.
  4. Acer Aspire One D250-1151 Keyboard Key Replacement: passo 4, immagine 1 di 1
    • Remove the round piece by taking the axils of the circular piece out of the holes located in the center of the square piece.
    • Make sure the circular piece correctly fits into the rectangular piece while laying flat. If it does not do this the circular piece is facing the wrong way and will need to be removed, turned around, and reconnected.
Conclusione
This process should work for any of the keys in the keyboard
Donny McKay
Membro da: 11/03/16
502 Reputazione
4 Guide realizzate
Baylor, Team 5-11, Williams Fall 2016 Membro di Baylor, Team 5-11, Williams Fall 2016
BU-WILLIAMS-F16S5G11
3 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 67
Tutti i Tempi: 4,606
